i want bigger tires in the front is this possible?
Old 09-04-08, 12:01 PM
ktown123
ktown123's Avatar
Default i want bigger tires in the front is this possible?
im running 235/35/19
the tires are just too thin for me im scared of bending the rims i want them alittle taller
i want them to look close to the look of the rears 275/35/19
im lowered on eibachs
and it rubs alittle in the front when i turn very hard
Old 09-04-08, 12:03 PM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
You can run 245/35 in the front. But you'll have to use heat gun to push the inner lining. Nice rims BTW.
Terrance
Old 09-04-08, 12:08 PM
ktown123
ktown123's Avatar
Terrance
thx
so this size will look pretty close to what the rears look ?
Old 09-04-08, 12:10 PM
javyLSU
2IS OG
javyLSU's Avatar
Terrance
What do you know about running 245/35's in the front???
Yes, you can run 245/35/19's in the front with Eibachs. Trust me, I know...
Javier
Old 09-04-08, 12:17 PM
ktown123
ktown123's Avatar
Javier
thx
so is this the best config to match the look of the rear tires?
i just dont want to buy another set again
Old 09-04-08, 12:26 PM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
It'll look beefy in the front for sure. You'll have a little more protection also on the lips. You're already rubbing a little bit right now, so you can't go too wide or too tall in the front.
Terrance
Old 09-04-08, 12:32 PM
javyLSU
2IS OG
javyLSU's Avatar
Well, it won't really "look beefy" in the front any more than it already is - the difference in sidewall between the 235/35 and the 245/35 is only 4mm. Terrance is spot on though about having to heat gun your fender linings if you're already rubbing. It's not a big deal, and pretty easy to do.
Javier
Old 09-04-08, 01:04 PM
llamaboiz
llamaboiz's Avatar
i always find it so interesting how ppl run the same size tire up front that i run on my back
Old 09-04-08, 01:42 PM
javyLSU
2IS OG
javyLSU's Avatar
Heh, if you had to drive through Pasadena, Rosemead, San Gabriel, Alhambra, or anywhere else in the Los Angeles area, you'd know why we run the sizes we do...
Javier
Old 09-04-08, 01:56 PM
sincityIS
sincityIS's Avatar
I ran 235/35/19 and 275/30/19 on my MMRs. I hit some big bumps as well and I never did anything to my wheels. If MMRs can handle it Volks definately can. Roads in Las Vegas suck too they are always under construction.
Old 09-04-08, 02:42 PM
ChrISF
ChrISF's Avatar
meh =/ i prefer the stretched tire look rather than the beefy look. but if its dependent upon the type of roads you drive on, then thats makes sense i guess.
oh btw, im going 215/35/19 on my front with a 8.5=in rim. =P
Old 09-04-08, 02:45 PM
javyLSU
2IS OG
javyLSU's Avatar
We're not talking about "bumps" here - I wish we only had to worry about "bumps." Think more along the lines of driving on a railroad track...
Javier
Old 09-04-08, 03:42 PM
Koz
Koz's Avatar
The way to get more cushion is to use a 17" wheel. A 225/45/17 is the same overall diameter as the stock tire. I was thinking of a larger sidewall myself with both front rims bent to *****!
Koz
Old 09-04-08, 04:22 PM
javyLSU
2IS OG
javyLSU's Avatar
Bigger tires? Yes. Smaller wheels? NEVER!!!
Javier
Old 09-04-08, 04:25 PM
VIS250P
VIS250P's Avatar
Yup I agree with u.. I knew 215-35-19 on 8.5 in rim with 35 offset or lower will not likely to rub the front fender..
Quick Reply: i want bigger tires in the front is this possible?
