oil change help !!
Old 09-12-08, 11:58 PM
Gumbee
Gumbee's Avatar
Default oil change help !!
today i did an oil change on my 250 and put in bout 5.6 quarts of oil and it barely hits the dipstick... dealer says put in 5.2 what do yall think?
Old 09-13-08, 12:30 AM
Gumbee
Gumbee's Avatar
sorry i didnt see the noob section
Old 09-13-08, 06:56 AM
BounceNY
BounceNY's Avatar
Check your manual, I believe its more like 6+ quarts.
Old 09-13-08, 07:37 AM
tC_demon
tC_demon's Avatar
Yeup my IS350 takes a little more than 6 quarts with filter...Just read the manual....the very last page should have all the specs.
Just checked my manual and its 6.6 quarts of oil with filter.
Old 09-13-08, 08:19 AM
nabbun
nabbun's Avatar
isn't it 6.3 w/o filter and 6.7 with?
oh and your dealer has a bunch of dipsticks working for them
Old 09-13-08, 11:29 AM
ISooNice
ISooNice's Avatar
i put 6.7 so after startup with filter its right on the line. my friend works at lexus and he said everyone puts 6.5
Old 09-13-08, 02:46 PM
Stokdgs
Stokdgs's Avatar
Default The manual says 6.6 qts for 2wd and 6.8 qts
for AWD. I just changed the oil and filter on my IS350 , couple days ago and 6.6 qts did not hit the top mark of the 2 marks of the dipstick, so I ended up putting in the rest of the 7th quart and it came up closer to the top mark.
DanF
Old 09-13-08, 04:22 PM
speedfoos
speedfoos's Avatar
BWAHAHAHAHHA!! Now that's punny!
At the OP. Umm.....why don't you just fill the crankcase until the it reads full on the dipstick? Just a thought.
Old 09-13-08, 10:20 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
manual says 6.6 but I used all 7 quarts today.....
barely touched the notch @dipsick...
Old 09-18-08, 07:25 AM
Flipsonic
Flipsonic's Avatar
Just got an oil change also but they put in 8 quarts. I checked the dipstick and it is over the two dots. Is there any negative effect to the car when this happens?
Old 09-18-08, 07:32 AM
Joeb427
Joeb427's Avatar
I'd drain a over a quart.
Too much oil in the crank case can cause more oil than usual to be sprayed onto the cylinder walls making the oil rings work very hard to clean the excess oil away.
Another concern about overfilling the oil is foaming. The oil will foam and result in less protection for your engine.Maybe seal issues too.
I don't know if a 1.5 qt overfill would cause these problems but why take the chance?
Old 09-18-08, 07:36 AM
Flipsonic
Flipsonic's Avatar
Ok thanks. I will drain the excess today. Luckily, it's only been a day of driving.
Old 09-18-08, 09:53 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
So who did this "oil change" for you and why did they use 8qts??
Not only did you over pay for the 8th qt, but over filling the engine with Oil is just silly and potentially very harmful...
Joe Z
Old 09-20-08, 10:36 AM
Flipsonic
Flipsonic's Avatar
Ok, took it back to the shop and they drained the excess oil but don't know how much. The dipstick show the oil level is still above the top dot by about 1/8 of an inch. The tech said this is ok. Is it? Is it really important that the level is not above the top dot?
Old 09-20-08, 01:36 PM
jimnordon
jimnordon's Avatar
Just ordered filters from sewell, they are listing 04152-yzza5 as correct filter. Other posts list -yzza3?, Is -yzza5 correct also?..... Thanks.
Quick Reply: oil change help !!
