Do ISF Rims fit on IS350?
Old 04-27-11, 11:10 AM
JMBillsta
JMBillsta's Avatar
Originally Posted by fr0st
what brand spacers did you use?
ichiba v1, used them on front and rear.
Old 04-27-11, 02:19 PM
305is350
305is350's Avatar
Another old picture, I used 15mm H&R spacers all around with the extended studs...
Old 05-02-11, 02:02 PM
ceatech
ceatech's Avatar
Just wondering, what size tires did you guys use for the front and rear? Any issues using the stock 225/40 19 and 255/35 19?
Old 05-02-11, 02:36 PM
ak89
ak89's Avatar
whats that car dropped on?
Old 05-02-11, 03:30 PM
305is350
305is350's Avatar
I went with 225/35 in the front to keep stock diameter and the rear is the same ISF tire diameter as well.
Old 05-02-11, 03:31 PM
305is350
305is350's Avatar
BCR coilovers .
Old 05-02-11, 05:43 PM
ceatech
ceatech's Avatar
Thanks for the reply.
Old 05-02-11, 08:56 PM
fr0st
fr0st's Avatar
do you have any rubbing issues with the fender liner? (during turns)
Old 05-02-11, 09:32 PM
305is350
305is350's Avatar
Not at all, it only rubs with the fender liner when I hit some deeeeeep bumps.
Old 05-02-11, 10:03 PM
fr0st
fr0st's Avatar
hm you sure? i have the same setup, 15mm 225/35/19 and I rub on turns. i mean its barely, but you should check your liner. i put some tape to protect some of the fender liner.
Old 05-03-11, 07:48 AM
Gustavo250
Gustavo250's Avatar
used a heat gun for the fender liner
Old 05-03-11, 08:13 AM
fr0st
fr0st's Avatar
oh no wonder, that makes sense. i'm thinking about doing that too.
Old 05-03-11, 02:26 PM
305is350
305is350's Avatar
fr0st you have to play with the heat gun a bit, but depending on how low you are is going to rub just with the fender tap anyway, unless you relocate it...
Old 05-07-11, 11:08 AM
flexthatdx
flexthatdx's Avatar
I have them on my IS350, I used 15mm spacers in the front and 20mm spacers in the rear. 235/35 fronts and 255/35 rears, lowered on coilovers
2is07is350 (06-02-23)
Old 05-07-11, 11:40 AM
ShadowISF
ShadowISF's Avatar
From what I hear, a 10mm spacer in the front (to clear brakes) will be good, and the rear is fine.
I have a set for sale actually in SoCal.
Quick Reply: Do ISF Rims fit on IS350?
