Damaged my fenders from rubbing for 2000 miles
I have my wheels for 2000 miles and I noticed that there were some rubbing noise after driving from San Francisco to Sacramento. When I reached Sac yesterday, I noticed that my fenders looked cut up from rubbing every day. I don't know if this is normal but I don't want water to get into my fender liner. Is there any fix to this? The hole is about 1/2 inch big and the plastic was pointing downward towards my tires which caused the sound. I was about to cut it off but I decided to push it inside the fender liner. The place where I am rubbing at is the place where the there is 2 flat head nails to remove that clips the fender liner together. Is there any way I can push it in to reduce rubbing? I know people said they use heat gun but how does that works? Maybe I should take a picture to make this clearer.
I am running 19x8.5 with 235/30/19 tires in front with 0 finger gap. If I set my coilovers to full dump on my rear, will I rub on 19x10 265/35/19 ? Thanks.
![](http://i24.photobucket.com/albums/c40/itzvictor/DSC00011.jpg)
![](http://i24.photobucket.com/albums/c40/itzvictor/DSC00012.jpg)
i think he damaged his liner maybe you will also get thread issues because i remember reading on here where people were rubbing and there were like two screws under the lining where it cut up their tires thread......
I think you can roll the fenders, its just harder on the is especially the rear.
Gotta pay to play! jk. prob too low, Im at 1/2 finger gap only rubbing on big dips. try setting ur coils stiffer. I would suggest to raise a bit. im on 20x8.5 n 20x10 225/30/20 245/30/20 most of the time but im streched.
