~Is it Safe rolling on 5mm Spacer Disc?~
Old 10-02-08, 11:41 AM
VIS250P
VIS250P's Avatar
Default ~Is it Safe rolling on 5mm Spacer Disc?~
How many of ya running with 5mm spacers disc in the rear? I put them on the rear and then I used a torque wrench (80Lb) to keep the aftermarket lug nuts tighten safe.. Do ya think is it safe with stock studs? 5mm spacers are not thick.. Give me a opinion of good and bad...
Old 10-02-08, 11:53 AM
Batmobile
Batmobile's Avatar
i think it will be okay. i have friends running 5mm in the front and rear...
"people" say anything under 15 is okay
Old 10-02-08, 11:58 AM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
You should be fine with stock studs for 5 mm spacers. If you decide to go anything more than that, you should have longer studs.
Terrance
Old 10-02-08, 12:01 PM
llamaboiz
llamaboiz's Avatar
you need to stop worrying
Old 10-02-08, 12:37 PM
javyLSU
2IS OG
javyLSU's Avatar
The 2" studs Lexus uses are shorter than most of the ones in use by the majority of manufacturers. The maximum spacer you'd be able to safely use is less than 10mm. Once you hit 10mm, you need to swap the studs out for longer ones.
Javier
Old 10-02-08, 12:57 PM
Batmobile
Batmobile's Avatar
that is good to know...
btw your car "cleaning" method...... i couldn't do it.... lol... was too scared to do it
Old 10-02-08, 01:28 PM
Hartawan
Former Vendor
Hartawan's Avatar
I hear that anything above 5mm you should get extended. I test fitted a 5mm and looked scary to me...
Old 10-02-08, 02:19 PM
accelerate
accelerate's Avatar
But you must all remember the studs are not the most important part of the wheel staying on correctly its the hub. The wheel must be snug on the hub. Just in case you didn't know.
Old 10-02-08, 02:23 PM
iSuxeL
iSuxeL's Avatar
What company's make a direct bolt on spacer kit for our cars? I'm confused how it works WITHOUT removing the stock studs.
Old 10-02-08, 02:56 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Im running 5mm spacers front and rear.. no issues so far, been about 1000 miles.
Old 10-02-08, 03:52 PM
javyLSU
2IS OG
javyLSU's Avatar
LOL, I don't blame you. Joe Z still can't believe I do this to my car...
Very true, which makes your selection of which "spacer" or "adapter" you use very important...
Javier
Old 10-02-08, 03:55 PM
johnnyboy
johnnyboy's Avatar
kics project
Old 10-02-08, 04:01 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
Javier
I can't believe it...I just use my 240mph blower to blow all that water off....hahaha
Old 10-02-08, 04:58 PM
VIS250P
VIS250P's Avatar
Are you talking about the spacer disc?
Old 10-02-08, 05:14 PM
tfz_hebe89
tfz_hebe89's Avatar
if you want to be safer maybe you should just get longer studs. with that you can have a peace of mind even it's only 5mm spacers.
what do you think?
Quick Reply: ~Is it Safe rolling on 5mm Spacer Disc?~
