Is it true?
You guys need to understand this, warranty will cover everything on your car. It doesn't matter which dealer installed it or which dealer you got the car from. If their giving you lip about having it installed somewhere else than your best bet is to take it up with the service manager, guys believe me...services gets $$ out of warranty work, it just depends on the manager and the adviser. My friend that works at Acura would do my OIL CHANGES under warranty when I had my RSX-S. I had a highly modded car, my RSX-S' trans went out a few times, replaced under warranty with all my mods on the car. And to get rid of the sound, they'll take the spring off, spray grease on it and put it back on.
I just gave up on it because 2 different people (dealership/corporate) said the same thing even though I didn't mention anything about the solution. So I'm guessing it's true.
Sigh Sigh.... I wish that there was someone that worked for the dealership on this forum so we can ask him/her.
aznboi27 where in texas do you live in?? Because i had no problem having my car looked at the dealer in dallas with my f-sport springs and shocks, but as the solution to the clunk, my dealer does not have a solution to it =(
the infamous clunk noise of teh f-sport springs. I read awhile back that if you use the emergency brakes overnight it might clear it up. it was on one of the threads here. search for it...
The reason your local dealer does not want to do it for free is because they didn't charge you for the install so they made no money from you. And corporate tells you to take it to the original dealer because they feel that they should fix it themselves since if anything was installed incorrectly they should be the ones to fix it free of charge without corporate paying a dime.
I remember that forum, i think by Joe Z. I've been trying that for a week now and nothing changed. I even got the emergency brake cable tightened up, but I think the only solution that was found was to get some silencers.
Both the dealership and corporate are wrong. With regards to the clunk noise check the f-sport warranty info. It clearly states that noise is not covered under warranty.
That said, get the spring silencers and be done with it.
As much we all like to believe that customers come first...service providers will sometimes have to sacrifice certian situations under policy. I only say this because Lexus is franchise own and corporate has limited influence in these situations.
Good luck to you!
ronf119
RX - 3rd Gen (2010-2015)
36
09-20-14 05:38 PM
