RedLine Time Attack – Finally did it!!!
#61
Tech Info Resource
You might want to consider raising the car up. It will go faster for sure and transition way better.
#66
What kind of prep did you do to the car?
suspension set-up?
tire pressures?
Post up the lap times!
How did your times compare with other cars in street class of similar weight and displacement?
And what is wrong with your sunvisors?
suspension set-up?
tire pressures?
#73
YOU NOTICED!!!!!!! haha mah lil E!
Coils 12k / 7k / damper adjustment and height adjustment seperate
tire pressure = 30psi front 28psi rear
Best lapTime 2:00min flat
1st place RWD = acura FactorX NSX (boosted 400+) 1:50ish
Sunvisors = t0e style!
Just representing like you!!!!!!! Keep it up man! Lux Sport!
It was FUN!!!!!!!!!!!!!! I love competition!!!! with the best!
Hey! I am glad you said this. Because, for that reason, i posted so many pictures. i wanted you to see what it was like, as if you were there
Project Mu, 6/4 - 7grand!!!!
Dam!!!!!!!!!!!!!!!!!!!!!! You ready!!!! ClubLexo is going to be representing!!!
