Window problem...help?
So I switched out my wood trim with the silver trim. I changed out the window switch plates on each window and now the "Auto" roll down does NOT work anymore plus I can't controll any windows from the driver side switch plate!!! Any ideas?
EDIT: Windows in roll down just fine but can't use the "Auto" feature and can't controll other windows from the driver seat.
Parts Vendor
I believe when the window switch is unplugged or the battery removed, you must reset the switch. I think the procedure is rolling the window all the way down, holding the window in the down position a few seconds, and then rolling the window all the way up, and holding the window in the up position for a few seconds. You have to do this with each window. It may be up first and then down.
-Regan
-Regan
Here is the reset procedure
1.Disconnect the negative battery terminal for 10 seconds .
2.Connect the battery terminal.
3.Turn the engine switch on (IG).
4.Halfway open the power window by pressing the power window switch.
5.If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps.
6.Turn the engine switch on (IG).
7.Halfway open the power window by pressing the power window switch.
8.Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
9.Check that the AUTO UP/DOWN function operates normally.
