Will the stock 18" wheels work on an AWD without spacers or anything. I know these are staggered setup so I'm wondering if it'll mess with my AWD. Would it be ok if I put the same size tires on?
I heard that using a staggered set up is not good on an AWD car.
i thought alot of people using AWD used staggered set ups? Running staggered is fine as long as the rolling diameter aka tire height is all the same i thought? plus say running bigger tire in the front would promote oversteer wouldnt it? idk just my 2cents i'm pretty sure you'll be fine as long as like i said you using the same tired size all around
Reason: i suck at spelling
Yeah, it should be fine, if the Outerdiameter of the tires are the same.
But the OE Rear 255/40/18 is A LOT larger than the OE Front 225/40/18
well I found a set of just the wheels for a great price and I would put my own all season tires, same tires front and back. Its just the staggered that's throwing me off.
safest would be a full set of 18x8 that way you can rotate your tires. im awd running staggered oems and ill go through tires quicker because of the staggered setup. other than that, it works fine
