Rotten egg smell
Old 07-12-19, 11:34 PM
djalvnjr
djalvnjr's Avatar
Originally Posted by VikH
It's your AC. I am assuming you are running your AC while you are performing these runs. When you WOT, your A/C turns off. This causes the egg smell. Do a test. Turn on the car and the air conditioning. Then turn off the A/C condenser. See if you get the smell.
So how do I fix this problem. I tried with my ac off and it doesn’t smell. So you’re right
Old 10-27-21, 11:56 AM
mistervj1
mistervj1's Avatar
Originally Posted by Jesknorr
I've been searching for the solution to this and have found it. In the trunk there are pressure vents or air outlet vents, vent valve, rear quarter outlet vents, are the names they have been called. They are accessed from the trunk one on each side, under where the amp is and on the other side. They are black vents with a rubber flap these break or even come off which in turn allows the exhaust to enter the cab of the car. All you have to do is replace them. $20-$30 for each one!! Also will fix the issue with the stereo not working when it rains due to the condensation that builds up around the amp!! No need to replace your cats or anything else!! I'm telling you, check these first!!
What's the name of vents? So I can purchase on eBay?
Old 10-29-21, 08:40 AM
MikeFig82
MikeFig82's Avatar
https://www.clublexus.com/forums/is-...amps-fail.html
CyberVlad
06-29-15 06:09 PM
gennacide
05-13-15 08:11 AM
rickyzee
RX - 3rd Gen (2010-2015)
11-23-14 06:43 PM
MEP7557
14
04-07-11 08:25 PM
dcook26
06-25-08 08:53 PM
Quick Reply: Rotten egg smell
