Rotten egg smell
Old 10-09-08, 06:49 PM
stvIS250
stvIS250's Avatar
Default Rotten egg smell
Hey guys, what's going on ... This is an interesting problem. Whenever I accl. hard and stop, I can smell, what I can only describe as a rotten egg smell. It just started about a week ago, I thought it was a fluke, but it's now consistent. Does anyone else get this smell or something similar?
Car is a 2008 IS250 AWD with only 3300K miles.
Thanks
- Steven
Old 10-09-08, 06:51 PM
Sytfu_IS
Sytfu_IS's Avatar
It's normal
Old 10-09-08, 06:57 PM
iialcii
iialcii's Avatar
smells like transmission or your cat :P
Old 10-09-08, 07:54 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
it's the gas......
Old 10-09-08, 07:56 PM
VikH
VikH's Avatar
It's your AC. I am assuming you are running your AC while you are performing these runs. When you WOT, your A/C turns off. This causes the egg smell. Do a test. Turn on the car and the air conditioning. Then turn off the A/C condenser. See if you get the smell.
Old 10-09-08, 08:08 PM
Evitzee
Evitzee's Avatar
There was an old TSIB for 2006 models with this problem, but should not be a problem for your model year.
File Type: pdf
Old 10-09-08, 08:18 PM
t0e
t0e's Avatar
2006 model issue?
I have not had this problem in a while.
Just make sure you have your A/C on Re-circulate..... NO EGG SMELL...
Old 10-09-08, 08:27 PM
Fizzboy7
Fizzboy7's Avatar
The egg smell (sulphur) is traditionally the result of a catalytic converter problem. Many new cars used to suffer from this, but it's becoming more rare (My 2008 does it too after hard acceleration with no A/C on.). If you guys are saying it's the A/C, wouldn't that be more of a mildew (musty) smell? A/C's and mildew go hand in hand. Rotten egg smells goes to the catalytic. If there's more to the story and TSB, my apologies. I haven't researched this particular Lexus issue yet.
coolrydz (10-30-21)
Old 10-09-08, 09:59 PM
wolverine
wolverine's Avatar
yea usually rotten egg smell is the cat getting its *** kicked
Old 10-10-08, 03:04 AM
stvIS250
stvIS250's Avatar
thanks guys, I will perform the tests stated above. and will also have the dealer take a look. Maybe a new cat is in order.
Old 10-10-08, 08:02 AM
tieu
tieu's Avatar
i get that when i shift at like 5-6k rpm
rotten egg comes from the cat
Old 10-10-08, 09:03 AM
slee18
slee18's Avatar
It also means that the car is dumping a lot of fuel into the engine and cant burn it all up and ending up being burned in the cats. it wont damage anything unless you constantly smell it.
Old 10-10-08, 11:18 AM
red-5
red-5's Avatar
Do a bit of research and find out what gasoline in your area has the lowest sulphur content. Around here (Edmonton, AB, Canada) that's Shell. The smell is severely reduced (but not eliminated) by choosing the right gas.
Old 10-10-08, 11:31 AM
2slow
2slow's Avatar
When i click on the button when the air comes from outside the car, it smells like sweat or dirty laundry. Is it the air filteR?
Old 03-31-19, 09:17 PM
Jesknorr
Jesknorr's Avatar
Default issue fixed!!! 2007 is250 rotten egg smell
I've been searching for the solution to this and have found it. In the trunk there are pressure vents or air outlet vents, vent valve, rear quarter outlet vents, are the names they have been called. They are accessed from the trunk one on each side, under where the amp is and on the other side. They are black vents with a rubber flap these break or even come off which in turn allows the exhaust to enter the cab of the car. All you have to do is replace them. $20-$30 for each one!! Also will fix the issue with the stereo not working when it rains due to the condensation that builds up around the amp!! No need to replace your cats or anything else!! I'm telling you, check these first!!
mistervj1 (10-27-21)
Quick Reply: Rotten egg smell
