Wheel torque spec?
Old 10-12-08, 06:53 PM
XprincoX
XprincoX's Avatar
Default Wheel torque spec?
I can't remember what the wheel torque spec is for our 2IS... was it like 80lb or 76lb?
Old 10-12-08, 09:17 PM
eric_r_ho
eric_r_ho's Avatar
70-80lbs is okay. Plus the torque wrench you're using is probably out of calibration anyway so just set it at 75lbs and call it a day. Just don't go any lower than that..
Old 10-12-08, 09:22 PM
javyLSU
2IS OG
javyLSU's Avatar
FSM calls for 76 ft/lbs.
Javier
Old 10-12-08, 11:15 PM
XprincoX
XprincoX's Avatar
hmmm alright thanks guys. yeah i think mine were kinda loose so i retorque them at 75 so it should be good now. I don't think i can tell the diff between 75 and 76 with my cheap wrench lol.
Old 10-13-08, 12:29 PM
iSuxeL
iSuxeL's Avatar
Just remember to add 1ft lb if you add an extension.
Old 10-13-08, 04:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,972 Likes on 2,403 Posts
??? Extensions make no difference. A crow's foot will, but not an extension, especially with 1/2" drive (which you should be using for wheel lugs.)
Old 10-13-08, 06:18 PM
eric_r_ho
eric_r_ho's Avatar
Are you serious? An extension can make a world of a difference depending on length of the extension. If you're using the standard 4 in extension plus socket on your torque wrench you add at least 5ft/lbs.
Old 10-13-08, 08:56 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Where did you read this BS? No one, not even the Air Force when working on airplanes arbitrarily adds to a torque value because you're using an extension. Who told you this flagrant lie?
skiracer
RX - 4th Gen (2016-2022)
03-11-24 08:53 PM
ISF_GG
Wheels, Tires & Brakes Forum
03-17-08 11:51 AM
clambros
04-04-07 09:49 PM
KevsSC
01-23-06 01:47 PM
ChuH
01-17-03 04:44 AM
Quick Reply: Wheel torque spec?
