★★★★★ Official Volk Owners Thread ★★★★★
#648
2006 IS350 RWD
looking to get Volk TE37 19x9.5+22, 19x10.5+22 . Car is on megan EZ coils with front and rear spc camber kit. Will i have to do any fender mods ? Also any suggestion on the tire size. Will I need spacers ? I'm not looking to tuck but just want to go flush.
I was advised to post in this thread.
thanks in advance
thanks in advance
#649
2006 IS350 RWD
thanks in advance
thanks in advance
If you want to ride low, one finger or less gap:
Megan EZ's flex a bit more and will rub on dips in the road. You will need to roll your fenders with a slight pull in the front as well as relocation of your fender tab. You will most likely still rub while driving. You will need to run some negative camber in the rear to help with clearance and run a stretched tire in the size 245/35/19. The front is going to stick out with a camber kit on it, run a 225/35/19. It will rub.
If you dont want to go too low:
You will still rub on hard dips in the road due to the flexible Megan EZ springs. I would still run stretched tires like above and would still roll all fenders.
No spacers needed.
More experienced CLers will chime in if they think otherwise.
#650
im trying to avoid modifying my fenders. id rather change the wheel offset than modify my fenders. Since the specs i posted wont work, what kind of te37's could i get that will not rub . as stated i dont want my wheels sitting sunk in. I will drop it down to 1 finger gap.
thank you for your input
#651
2006 IS350 RWD
I have would go with a much higher spring rate coil such as 14/12 if you wanna roll stanced and looowww.
#652
#655
#656
thanks, rear fender not rolled. no rubbing issues, however i havent had anyone ride in my back seat either. my fronts are rubbing when i have a passenger, so seems like i will still have to roll fenders to avoid rubbing at this height. also my coils are megans and settings are set to soft
