LED DRL flicker solution?
Old 11-03-08, 12:00 AM
  #46
350ISRYDER
350ISRYDER's Avatar
Default ...
Originally Posted by chikken
just curious....what does your DRL look like when its off?
The leds are covered with a clear/white plastic housing...it looks better than the V-LEDS (IMO) because the V's you can see all the leds...here is picture!
I'll try taking pictures of the bulbs in the housing in the day...
Old 11-03-08, 05:10 PM
  #47
vietdeluxx
vietdeluxx's Avatar
Yes, please take pics so we can check out the difference. Thanks!
Old 11-04-08, 04:37 PM
  #48
love67
love67's Avatar
i just got it and intalled it in 15 mins. since no one posted a picture from inside, therefore i took a picture for you guys.
this picture was taken from the intake side of the car. there is alot of room for this little box. in the picture which i wrote the box is where the box goes, and so the lines and plus is at other side. anyway there is alot of room and i just wanna give you guys an idea of how to fit it in...
thanks for looking.
Old 11-04-08, 07:27 PM
  #49
joaco
joaco's Avatar
Love67
Great picture. One question, do you have factory HID's and if you do the placement of the box in your picture gives the AFS system to operate freelly?
Joaquin
08 IS250
81 TE72
Old 11-04-08, 07:39 PM
  #50
love67
love67's Avatar
^^ i don't have factory HID. im sorry im not good at english, and i don't get the AFS part that you ask.
Old 11-05-08, 11:18 AM
  #51
joaco
joaco's Avatar
love67
Disreguard the last portion of my question, your car doesn't have factory HID.
Thanks
Joaquin
08 IS250
81 TE72
Old 11-05-08, 11:23 AM
  #52
joaco
joaco's Avatar
D.Jobin
Do you have a picture of your install? I also have factory HID's and will like to see were you put the modules so the AFS system work freely.
Joaquin
08 IS250
81 TE72
Old 11-05-08, 02:44 PM
  #53
D.Jobin
D.Jobin's Avatar
Originally Posted by joaco
D.Jobin
Joaquin
08 IS250
81 TE72
Look at the top of pg. 3. I don't have any pics and I am not taking all that apart again.
Old 11-05-08, 08:16 PM
  #54
papaalex
papaalex's Avatar
my car has HID/AFS; i have no pics either of the inside but you can tuck it on the outer lower part of the headlight casing without causing any problem on the AFS
Old 11-05-08, 10:58 PM
  #55
350ISRYDER
350ISRYDER's Avatar
Default Here u go...Piaa Tera DRL Bulbs on and off in housing!
Took some day pics of this bulb.
Old 11-05-08, 11:01 PM
  #56
350ISRYDER
350ISRYDER's Avatar
Default 2nd pic...
Here u go again!
Old 11-06-08, 06:19 AM
  #57
D.Jobin
D.Jobin's Avatar
That doesn't look nearly as bright ^^^^^
Old 11-06-08, 08:34 AM
  #58
350ISRYDER
350ISRYDER's Avatar
Default ...
they're not as bright as the V-leds
Old 11-14-08, 08:20 PM
  #59
Dj_AmtraX
Dj_AmtraX's Avatar
does it flicker?
Old 11-14-08, 08:25 PM
  #60
chikken
chikken's Avatar
they're not as bright as the V-leds (v's have like 2-3x more leds, but the piaa's get the job done)...more is not better for me, cuz I like subtle changes! Plus IMO, it has a better color than the v's. Piaa's burn purple white in different angles and it all depends on the time of day...it can be seen when the sun is out too. Between 430-7pm...these lights look cherry! But like I said, it depends on what everyone likes...
picture was taken @ like 6ish...
well, good luck to everyone with this mod...I like it!
thanks for the pics...you should come to our starbucks meet i wanna see them bulbs in person looks nice.
Quick Reply: LED DRL flicker solution?
