DRL Piaa 9005 Yellow 55w ?
Will they be ok ? I'm worried about burning the plug. Happened in my previous car. Probably b/c i was using a 110w bulb maybe....Anyone got these in their Is350? If so, any pictures perhaps? How is the install ? Pretty easy ?
Thanks for any advice !
I have 55w in mines and it burnt the plug, if I were you invest in the high output connectors they sell, I replaced my harness and then added the high output connectors and nothing so far. Others might say you don't need it, but trust me get it. It'll save you the headache in the long run. And it'll fit inside the headlight so you can close the cap completely to prevent moisture from coming in.
thanks for the advice! where is a good place to search for the connectors...? im thinking of going with the piaa 55w yellow 2500k in 9005 size....With connectors and those bulbs, should i be ok?
I think the DRLs are rated at 35w, cause I can show you the burnt connector. I was lucky enough to find a guy on ebay that was selling an OEM harness for dirt cheap. You can chance it if you like, but I wouldn't. Not after what it did to mines. $20 for the price of NOT frying your whole harness is very well worth the money IMO.
arnt the DRLs the same bulb as your highbeams? but they run at half power? anyways.. sorry to hear some of u ended up with burnt harnesses.. maybe its good to invest in the connectors.. i have yellow DRL/highbeams for about 8 months now.. so far so good..
