5mm Ichiba spacer question
ya you will need to keep your hub rings if u get the ichiha 60.1 bore . There is a thread like mike mentioned on how to change your extended studs, I remember reading over it, but it was for only front studs. Good luck
I'll get mine after I change my tire set up.
Let me know how it goes.
Since I have to change studs anyway, now I'm thinking to get 10mm spacer to make it +35. More flush is better..
Will I have any rubbing issue with +35 in the rear with 275/30/19 and 1 inch drop? I know +40 won't, what about +35 in that setup?
Are you getting 5mm spacer and will change your studs too, iialcii?
Will I have any rubbing issue with +35 in the rear with 275/30/19 and 1 inch drop? I know +40 won't, what about +35 in that setup?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
are you 9.5 or 10" rear
you may have slight rub over dips and large bumps but nothing that should cause any problems. you could always go with a 265/30 if you wanted. Personally I would stick with the 275![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
if you are 9.5 then the +35 is perfect and you wont have any issues.
No, it's not the same. Spacers change the relationship between the centerline of the rim and the centerline of the wheel bearing. To ensure the wheel bearing stays within design limits, the OEM wheel's centerline is aligned with the wheel bearing's centerline. Spacers move the wheel's centerline off the bearing's centerline and create a constant vector load on the bearing. This shortens the service life and could potentially lead to catastrophic failure of your wheel bearing. That's the downside.
sincityIS
Suspension and Brakes
12
02-19-08 04:33 PM
