Oil filter?
I'm going to try to do my first oil change coming up on my 10k. My question is, when I put the oil filter back on, do I first tight with my hand and then slightly more with a oil filter wrench? And, how tight do I tight the oil drain plug? I don't have the torque wrench. Thanks in advance.....
2IS OG
Haha, if you ever made the mistake of tightening the filter housing with the wrench, you would NEVER, EVER get it off. Even hand-tightening, sometimes it's difficult to remove. You'll notice that there's a point where the filter housing will just stop turning. STOP RIGHT THERE. That's as tight as it needs to be.
Javier
Javier
Tech Info Resource
This must be why Lexus says:
Sorry, but despite the advice you've seen here, it is supposed to be tightened with the tool. But don't take my word for it, I've only done it 9 times so far and never had an issue getting it loosened. Quality tools help a lot.
(f) Using SST, tighten the oil filter cap.
SST: 09228-06501
Torque: 25 N·m (255 kgf·cm, 18 ft·lbf)
SST: 09228-06501
