Will 19x9 (+31) fit on front?
I have a set of wheels, the front specs are 19x9 (+31) offset, will these fit under the front fenders? If so, what is the widest tire i can run with them? I plan on lowering ~ 1.2". Thanks
You may have to push the tabs up..... The fronts don't really have a ledge to roll, but you could pull them a little, but I don't think you'll have to. I'm running 19x9 +22 up front and did a little pull and pushed the plastic tab up. I still rub a little on dips and hard turns, but nothing too bad. Oh, I'm running 225-35-19 up front.
yoitskenn
12
11-06-12 06:29 PM
Dan@FSM
GS - 1st Gen (1993-1997)
07-23-08 09:03 AM
