Right Rear Mud Flap loose/hanging HELP ON WHAT TO DO
A few days back, after coming out of the tollbooth, I unfortunately hit roadkill that was pretty big on the highway. Now, my rear mudflap is loose and hanging but i kind of pushed it back in. however, its not as tight as the other mud flaps. will the dealership do it for free or how can i fix it?
thanks in advance
thanks in advance
thanks in advance
thanks in advance
Gee, it would be like you hit roadkill & your front bumper came off & now you what the dealership to put it back on for free!!
It's easy to fix yourself, just screw back on.
2IS OG
He's probably referring to the air diffusers that sit right in front of the wheels near the rear of the side skirt. I (and several other CL members) have had problems with the clips coming out by themselves - repeatedly. I solved this problem by simply zip-tying the diffuser to the holes in the chassis. Problem solved.
Javier
Javier
There is 2 push pin type clips and a bolt that hold them on. Just go to the other side of the car and take the middle clip out and transfer it to the outside hole on the right side. Then you can go to the dealer and buy a couple of new clips.
because im at school right now, i dont really have time to go to the dealer so i am just going to use the ziptie method. what hole (in the flap and the chassis) would the zipties fit through?
appreciate your help
anyone know the part number for the clip? on the passenger side both clips are gone. driver side both are there.
