If i want to slam my car what can i do to not rub alot
Old 11-18-08, 10:31 PM
Hartawan
Former Vendor
Hartawan's Avatar
Stretch those tires and don't go too aggressive on the offsets.
Old 11-19-08, 12:14 PM
VIS250P
VIS250P's Avatar
I agree what he said.. There are more other way to prevent rub too
Old 11-19-08, 12:43 PM
VF84
VF84's Avatar
yeah, stretched tires and rolled fenders will all help. u could also make sure the springs u are getting are stiff enough. have seen some slammed e36 m3 dinans where i could not even stick my whole finger between the fender and the tires, yet, the liners inside the fender still perfectly untouched. u'll probably get a pretty stiff ride, but that's what u get for slamm'n it.
Old 11-19-08, 01:30 PM
t0e
t0e's Avatar
Originally Posted by VIS250P
I lower my ride with Megan LP and the car height is pretty low.. The front fender bracket near the headlight are gonna work with the right size tires (215-35-19 or 215-40-18) with a high offset front rims.. When I had 18x8.5 31 offset in front and the tire size was 215-40-18 and they rub like crazy.. The front tires and low offset rims stick out a little and they touch the fender bracket.. When I recently used 19x8.5 39 offset in front and the tire was 215-35-19 and it dont rub cuz the front rim insert in more.. I looked underneat the fender and see if the tire touch the bracket near headlight.. There are more room clearnace between the fender bracket and headlight area.. I found out the answer is right size tire and high offset in front will be ok.. I prefer get high offset front and low offset rear.. That is just me..
Dont want to RUB?
Keep your tires SMALL and your Offsets High (40+)....
Cant get any more simple
BPVIP
04-15-13 04:14 PM
Vishuz
04-17-12 11:13 PM
Silver'04
04-04-11 10:09 AM
SorrGwa
09-26-09 01:22 PM
tonydt1g3r
Wheels, Tires & Brakes Forum
03-27-06 09:17 AM
Quick Reply: If i want to slam my car what can i do to not rub alot
