What's that sound?
Old 11-19-08, 06:28 AM
Jefe's IS
Jefe's IS's Avatar
Default What's that sound?
I hear a noise coming from behind the steering wheel/dash. It happens every time I shut the car off and open the door. It only happens once you open a door, drivers or passengers. It sounds like a motor of sorts. I do believe it to be normal. Just wondering if anyone knows what it is.
Old 11-19-08, 06:46 AM
nabbun
nabbun's Avatar
isn't that the steering wheel lock?
Old 11-19-08, 07:12 AM
papaalex
papaalex's Avatar
i hear that sound too, probably just the steering lock nothing wrong
Old 11-19-08, 07:24 AM
albertkey
albertkey's Avatar
Its the tilt away motor in the steering wheel. I had the feature disable and it still makes that sound when I start and shut off the car.
I think that maybe the sound you are hearing!
Old 11-19-08, 09:11 AM
ChrISF
ChrISF's Avatar
is it the same sound it makes right after you hit the start button and right before the car starts?
like "merrrr" then a split second later, the engine starts? that noise?
Old 11-19-08, 09:28 AM
myhusky
myhusky's Avatar
steering wheel lock i think
Old 11-19-08, 09:53 AM
chris07is
chris07is's Avatar
i think that sound comes behind the steering wheel. due to the smart key, to recognize that its ready to be re-started again...IMO...but i know its NORMAL
Old 11-19-08, 10:43 AM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
Is the steering lock, I dont have the auto tilt steering wheel and it does that, It just locks your steering wheel in place when you open the door and get out.
Old 11-19-08, 12:17 PM
tex2670
tex2670's Avatar
That's different. The steering wheel lock doesn't trigger till the door opens.
Old 11-19-08, 05:17 PM
albertkey
albertkey's Avatar
Wow! There is a motor that triggers the steering wheel lock. I never knew that. Learn something new!
Old 11-20-08, 06:38 AM
Jefe's IS
Jefe's IS's Avatar
Thanks for the info.
Old 11-20-08, 08:57 AM
hapaboy
hapaboy's Avatar
the 08's and probably newer have a less rough sound. all the 06's i get into sound like they are drilling bone! i wonder if they'll have a TSB?? heheh! wishful thinking.
Old 11-20-08, 10:29 AM
mikeho
mikeho's Avatar
I'm guessing that it's the motors for the climate control system. It's most likely shutting off the vents to prevent dust and debris from coming into the car.
But that might be wishful thinking of well-designed technology...
Old 11-21-08, 06:25 AM
Jefe's IS
Jefe's IS's Avatar
It is most definitly the wheel lock motor. I played w/ it a bit and the wheel locks as the motor runs.
L3XUSFAN
ES - 6th Gen (2013-2018)
12
01-27-19 09:50 PM
destro888
RX - 4th Gen (2016-2022)
09-10-18 07:09 AM
blksolara
07-09-15 03:26 PM
islandsnow
09-02-06 10:24 AM
tjp
03-04-06 07:02 PM
Quick Reply: What's that sound?
