UPS man just dropped mine off! Gonna try and do them later tonight wish me luck. Hopefully I don't end up messing anything up, will post some pics hopefully by tomorrow.
^^^i think in either this thread or another one, i forget which, they said that they didnt use it because the turn signals didnt draw much power. but i ended up using it just to be on the safe side.
^ Did you install it? I didn't get a chance to mess with mine today. Took a long long nap..
After a loooong day yesterday of tinkering I finally go them done! I must say the hardest part was the routing of the wiring, talk about a PITA! took me a good 3 hours to get them done. I will try to post some pics later today.
did anyone use the supplied fuses that come with the wire packet?
you dont need them, i had the tech at the dealer help me tap the wires and he said they where not necessary...I never had any issues for the few months that I had them on.
Everyone is getting them done..cept me...I think something is loose because i tapped into the big red wire like Thien said, because it's always on and nothing. I think i tugged on the wire too much and the extension came loose.
It should not be a big red wire. The wires you tap on to are small. They are towards the bottom of the pile. A light green one and a red wire are the ones you need to tap onto. I did the trial and error for both of them since there are a couple of them that are the same color. Good luck
