Strange Choke when gear change
hello
i have a 09 is250 automatic and every time i slow down and i think it to drops to 1st or 2nd gear .. then i give gas again.. the will feel like its gonna stall or its like the gear change is really rough .. like the whole car chokes a bit.. is this normal ? or should i get this checked out ?
thank you
thank you
My 08 is250 does it too. But you get used to it and learn when to accelerate so you dont get that "stalling" feeling. I usually dont get that feeling as much anymore. My mom and sisters 05/04 camry does it too. Weird.. must be a toyota/lexus thing.
Same here, my 09 250awd is doing the exact same thing when she changes gears. I feel the slight choke on every gear change, but it is alot more noticeable on the 1st and 2nd.
I have less than 1.5k miles on her right now, when do you think the ECU will finally learn my driving style? I usually drive during rush hour bumper to bumper, and this choke is getting kinda annoying...
I have an 07 and it does the same (approximately 22000 miles). If I remember correctly it happens when you try to accelerate a bit when it's not in gear and it hooks the gear from the added rev. I notice it when I'm in mid-shift (gears still changing) during downshift then it chokes back up to a higher gear. Completely normal. Once it adapts to your driving it's minimalized where it's unoticable unless you change your driving suddenly.
For future reference if you start to drive your car like on the track, the shifts change also. Typically on normal cruising it'll be in 6th gear at 40mph but under heavy use (like in a race) it'll stay as long as 60mph before 6th gear or even longer depending on conditions.
Sorry to be off topic but, when i change from P to D, sometimes i hear or feel this THUMP like in the trunk of the car, (as if a soccer ball o something is in the trunk and hits the walls of the trunk) Also, it happens when i slow down or to a stop! its really annoying!
Anyone else with this problem? Delearship?
THANKS
THANKS
THANKS
THANKS
i get that too >,<... atleast i know other ppl get it too ... so its not that bad
i get that soccer ball sound when i come to a stop also. probably just another quirk from this car. and ect stands for electronically controlled transmission, and the ect-pwr/snow button is right next to the trac off button under the engine start button.
and dont want to make a new thread.
Im going to test drive an '06 is350 tomorrow, the '06 doesnt have the trac off button, so how do you turn that off? somethin about foot peddling??
with the '06 have the ect button? also want to try out the paddle shifters, how do i transfer auto to semi using the paddles?
koreanpers
Performance
11-18-04 04:43 PM
