Modded Head lamp LED Front Turn Signals Amber&White (merged threads)
#50
...I used a flasher relay instead..so I dont have to worry about heat. I will post a picture of it next
#51
flasher led fix
Here is a picture of the flasher fix...but to install this you will have to remove your instument display..its behind your dash..not hard.. but intimidating to do. And you dont get turn signal flash when you lock/unlock your doors....But more safe than resistors FYI: as an alternate to using resistors
#54
#55
Crap your Right...thanks..I just noticed that after taking a peek under the dash......damm Lexus illustration made me take it all apart
#58
This is where I got it from...but you have to mod your headlamps,wiring and change exsisting sockets to use the (non-oem)7443 type dual color lamps.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
If you want to simply just get either amber or white led turn signal bulbs and use your exsisting 7440 (oem) sockets with no mod then just get these in what ever color you want
amber
White
Good luck....and BTW to change the bulbs out, you have to remove the bumper to get access to the turn signal bulbs.
amber
White
