Will G37 wheels fit?
I was parked right next to a new G37 and the wheels look just like the IS wheels only bigger.
Does anyone know if the G37 wheels would fit on the 2IS?
But I think that post was from an old G-35 model wheels..not sure if the G37 is different.
I think you are right, probably the G35 wheels before the G37 came out. The wheels looked really nice. If my memory was correct, it was a Breakwater Blue 2Gen. I could not locate the thread.
I just came out of a G35 Coupe into an F. The offsets on the G35 coupe are far more aggressive than they are for the G35 sedan or the G37. My 8.5/9.5" Nismo LMGT4 wheels had offsets of +25mm in front and +30mm in back. I'm still trying to find out the offsets of the BBS wheels on my F, but I believe they are more conservative.
Lou
Lou
hubcentric rings are highly recommended, as the hub diameter of the G37 multi-spoke wheels are 66.1 and the hub diameter of the 2is is 60.1. as such, you will need 66.1-60.1 hubcentric rings.
also, to maintain stock rolling diameter, run 225/35-19's up front and 255/35-19's in the rear. this is especially important if you are lowered, as any larger-sized tires will cause rubbing between the tire and the wheelwell liner.
the G37 multi-spoke wheels are 19x8 up front and 19x8.5 in the rear. they will bolt up to the 2is.
also, to maintain stock rolling diameter, run 225/35-19's up front and 25/35-19's in the rear. this is especially important if you are lowered, as any larger-sized tires will cause rubbing between the tire and the wheelwell liner.
oh.. i think i ran 255/35 in the rear.. with +30 something offset... mayb thats the difference.. but some people may rub with 255/35-19 if lowered on S-Techs... safer to go either 245 or 235/35
