Rain-X Latitude
It's not in the MSDS. If it contained sulfuric acid, it would have to show up there. Ingredients are:
So I'm really wondering where you got the information about silicone oils and sulfuric acid. I can see the unspecified clays being silicon based clays, but not silicone oil.
Code:
Chemical CAS No / Unique ID Percent Clays (unspecified) 000000-27-6 1-10 Ethanol/SD Alcohol 40 000064-17-5 70-95 Isopropanol 000067-63-0 1-10 Thickening agent(s) 999999-50-7 1-5
I still think, however, that there are better products on the market.
I think wax is an OK solution, but what I've found is that it tends to streak and leave lines as the wax wears in certain spots (i.e. in the wiper pattern). Have you found a wax that doesn't suffer this problem?
There's another discussion going on about this. I use rejex
https://www.clublexus.com/forums/is-...se-on-2is.html
i had a recent problem with my factory blades... they werent wiping the water off very well, but that was due to the fact that my right blade overlaped on my left blade because the left side blade **** came loose...
I've tried tons of different wiper blades on my previous cars and found that the OEM Toyota/Lexus ones worked the best. On my Integra I pretty much matched the size of the blades that our ISx50's come stock with. Apply some Aquapel every 3-6 months and you should have no problem keeping the windshield clean.
Imprezario
06-29-15 08:38 AM
