Have factory sound system, want to upgrade
#31
A cleaner signal perhaps. Playback of DTS CDs for another. We already established that a CD player with SPDIF can play those after all.
#33
Now the stamp is important?
What a difference a day makes!
BTW, got a quick break in the rain and ran outside and poped the cover above the amp... there's 3 connections going into it as far as I can tell, but I can't see what they are since they're at the back of the amp, right near the wall of the trunk...and the weather was too bad to try and get tools out, unbolt the amp, and remove the whole thing for nearer inspection.
Anyone got a pic of the back of an ML 2IS amp? I'd easily be able to tell what's populated and what isn't with the visual reference against where I saw the cables going.
#35
tqlla3k,
Just wondering where you bought the ML DVD changer for, how much, and if you have the part number for it?
Right now, I have NAV without ML so I really want to get the DVD Changer. I'm guessing all I have to do is buy the DVD changer unit (bottom part of NAV) and it's going to be plug and play swap?
Thanks
Thanks
#36
Its a beast of a job. I would not suggest doing it, unless you are very comfortable with cutting a lot of wires. There are about 40 wires that must be spliced in order to get the Nav unit working.
#39
tqlla3k,
Thanks
Thanks
1) You need a J63 cable. Its a blue video cable that attaches from the DVD unit to the Navigation unit. This cable is a part of the cars wiring harness, and I do not think you can get it seperately
2) The ML DVD changer is very expensive($2500-$3000).
I got extremely lucky with that NAV/ML unit. Someone in the classifieds section was selling it with the cars wiring harness. No one wanted to pay money for something they were not sure would work.
I bought it for extremely cheap and sat on it for a year, until someone from on this board installed it in his car. He helped me with what wires needed to be spliced. Unfortunately by that time I had already sold my 06, non nav car and special ordered a NAV/ML car. Which is why I installed it in my cousins car.
#40
I don't think any common home-use burning software will burn any of these formats, but there's some higher end software that will, if you have a valid source to burn em from.
Here's one place that seems to carry some stuff, tower records has some too (online anyway)
http://www.5point1.com/Products.html
#42
The ML units do not support DVD-A anyway. Even though they claim to support DVD-A, the ML units will only play the DTS or DD track. If those Tracks do not exist on the DVD-A... then no audio will play.
