Oil Change - what, how much, and where
the dealer does not use a full synthetic like mobile 1 for the standard oil change. If they do have it it will definitely be more then $50. Some dealers will allow you to bring in your own oil/filter and just charge you for the labor if you guys are looking for that.
Merkur Fanatic
Mobil 1 is a bit too expensive for my taste, so, I've been sticking with Semi. As long as you change your oil every 3-5k miles, you'll be fine.
I use Motorcraft Semi-Synthetic 5W-30 which you can usually get for the price of reg oil and Wix filters from the local auto parts store which are about 4 bucks.
Tech Info Resource
Merkur Fanatic
No doubt, but, you'd still need to change the filter every 5k. Either way, as long as it's being changed at regular intervals, it's all good.
Tech Info Resource
I did this with my Supra once. They put Pennzoil in it instead of the Red Line I gave them. It coked and coated the engine with varnish in 5k miles. I'll never, ever, give anyone my oil to put in my car. I had to use paint stripper to remove the varnish. Needless to say I was livid.
Dude are you serious? Autozone, Pepboys, Chief auto parts. Don't take this personally but have you ever removed a bolt from anything? Seriously, its one bolt..take it off, let it drain, put it back in. While its draining, take out the filter. Wow make it easier pay me 20$ I'll do it for you. I can't do mine cause my car is so damn low but my friend does mine for 10$, and hes a Lexus tech, so..but you dont need to be a tech to CHANGE OIL!!
