IS250 Retrofit in Progress
#64
hey mahcah
I just got my E30 lens. Excellent condition save for a very small scratch on them, but I doubt such a fine imperfection wou ld make much of a noticeable difference.
![](http://i2.photobucket.com/albums/y12/holyherbiness/IMG_1012.jpg)
I gotta take this sucker apart too. Can't wait to get started.
![](http://i2.photobucket.com/albums/y12/holyherbiness/IMG_1013.jpg)
#66
Our ISx50 projectors are 3". It wont fit without alot of cutting; you may need to use a shroud (barely enough room, i think) if you go this route to cover up.
Its probably easier with the TSX's or FX's.
Im starting to debate whether or not to start on this fog retro.. hhhhhhhhhhhhhmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm...
#68
I am actually thinking about doing this project also, I am in the process of purchasing the bosch mini projectors with clear lens. It's small enough to fit into the foglights and I will try to fabricate a bezel or shroud if i can't find the right ones. Oh yea I am about to head home right now, so when I get home I'll take the pics for you.
I loook forward to the pictures T. Thank yas
#71
It depends. If there was alot of cutting and it is visible from the outside and you want to cover it up, then a shroud is recommended imo for looks. The method with using the camry projectors (2.5") would not require me to use shrouds because its a nice fit; the only part of the fogs i would cut is the back of the housing to get the projector inside the foglight. Now if I wanted to dress it up, I'd use a shroud (that would fit inside the foglight).
On the extreme side, if I wanted to use the ISx50 projectors (3") I would have to do heavier modification, cutting and dremeling to make the projector fit inside the housing. More likely the cutting/dremeling would show imperfections; this is were I can play dress up and cover my scars by using the shroud.
So yep, it depends....
#72
Here are the pics as promised! Sorry the car is dirty have to wash it soon.
These bezels are the ace flanges that I mentioned
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight001.jpg)
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight002.jpg)
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight003.jpg)
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight004.jpg)
With the headlights and fogs on ( Philips d2s 4300k rebased 9006 HID bulbs)
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight005.jpg)
Notice the flicker of colors!
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight006.jpg)
V-led DRL bulbs.
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight007.jpg)
As you can see limited amount of space, but enough to fit my hand in there to swap out the bulbs. It's a pain in the a** but well worth it. Don't mind the drips on the projectors, it's just a little overflow of the jb weld.
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight008.jpg)
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight009.jpg)
V-led DRL bulbs.
![](http://img.photobucket.com/albums/v58/rnsmelody/Lexus/lexusheadlight010.jpg)
