Aftermarket HID kit owners.. ballast placement??
Is it a slim ballast with ignitor or full sized with built in ignitor?
Do a search on the forums
https://www.clublexus.com/forums/is-...-pictures.html
This is a thread that can give you some helpful ideas. There are others like it, but do a search.
I stuck my ballasts for the foglights behind the reinforcement bar on the sides. I velco'd + ziptied them so they aren't going anywhere! Some ballast have long wires so you might be able to put them there also and route it up to the headlights for a clean and out of sight installation.
Thats NOT good my friend. Your going to end up ruining your headlight. Your supposed to drill a hold in the cover. I believe 5/8's just big enough to run your wires through there. I tried my best sealing it when electrical tape as well to make sure no water would be able to get in them.
I used a one inch drill bit on the back cover and wired it through with a rubber grommet. Didn't seal with electrical tape, and has held up through all kinds of conditions without a hitch
I have the slim ballast kit from XD and I mounted my ballasts near the shock towers.
I have another kit with the all-in-one, thicker ballast that I'm going to use for my fogs. I'm trying to figure out how I'm going to mount them with having to remove the front bumper.
ok so i put on one side, the passenger side, i stuck it on the back of the reinforcement bar, then tucked the wires away, made a small hole on the bottom of dust cover for the excess wires.. not the hard part is the drivers side, not much space there!! gotta do it in the morning with some daylight.. ill get pics up soon
