Spark plugs...which brand to use?
what's your source? When I pulled my plugs out they were denso and the last time I checked NGK doesn't make any plugs for the IS350
fyi...the part number on your stock plug is probably a special part number for Lexus. If you go to a part store the plug will be a different number. (source: Denso technical support)
haha you have to check this out ! i recommand BOSCH
http://www.boschautoparts.com/Products/SparkPlugs/
get Platinum Ir Fusion
if i remembered this correctly this spark plug can last more than 100,000 miles
http://www.boschautoparts.com/Resour...3.5+2GRFSE+GAS
Only items Bosch has for the 2IS are cabin filters and wiper blades.
IIRC the 2IS requires long-reach plugs too
