What spacer to use for stock 18s?
damn... it suck i was looking at mister T's spacer pics... i like it but i want to go an extra 5mm more in the back... but dont know how that would look... so instead of 20mm, use 25mm... any one have pics with 25mm spaces for the rear with stock 18" rims??? please help
well i read it but the thing is that you said they are close to stock... if you look at Mister T's thread https://www.clublexus.com/forums/is-second-generation/371272-wheel-spacers-installed-before-after-pics.html it looks really close to your set up... and you an extra 5mm off...
(Plus even if my wheel were 5mm more aggressive than the OEM 18x8.5, I am running 5mm more on my spacer as well so that means you will be fine with that offset too right?)
If you look at his pic #6, you can see he is less aggressive than mine. Also I bought my spacers off someone who ran the spacer on a set of OEm 18" and basically it looks the same as mine, no rubbing, no fender mods needed.
JDKane527
03-24-09 07:23 PM
