paddle shifter
#31
I think I would know what the car is capable of doing and not doing. But anything can and will probably happen. You can be the safest and smallest person out there, but experience is knowledge.
Your brakes are much more efficient in terms of slowing down your vehicle.
its great for crazy traffic, and constant stops
Engine braking to minimize wear on pads?
ha.....ha.
I believe Kurtz explanation on paddle shifter(shifting) is clear cut.
If your aware of the Murphy's law like you mentioned, why increase the risk of failure...
#32
B mode is something that I've only ever seen on hybrid cars, so it doesn't necessarily apply here...
From just a couple of minutes reading on a Prius forum it appears to be intended the same way you ought to use downshifting/engine braking on our cars though, that is if you're going down a steep grade on the side of a mountain or something and you need to avoid fading the brakes.
This post suggests how to use it to best effect with a hybrid system in hilly driving, and seems informed, but I'm not a hybrid owner so I can't say if it does anything else differently or how accurate this guys info is.
http://priuschat.com/forums/prius-te...tml#post668141
So if it really does work similar to manual down shifting or down shifting on the 2IS I would as before suggest you avoid using it in lieu of the brakes in normal traffic, and keep its use limited to when you really -need- it such as the mountainous driving I mention.
#36
#37
lol you think that would work in traffic??? if your going from 2mph to stop lol. you know what... if we are concered about wearing out the brakes or wearing out the transmission...maybe we should just learn to stop using the front bumper and the rear bumper of the person in front of us... you'll probably save BOTH the BRAKES and the TRANSMISSION. genious i'd say
#38
![](http://img134.imageshack.us/img134/478/guinessbrilliantmb7.jpg)
#39
Don't get me wrong, I still use the brakes if I need to slow down faster, but using engine braking has taught me to not accelerate so hard and do more coasting when possible. And I don't have to sit on the brakes at a light.
#40
i'd have to agree with Kurtz, using engine braking in my SLK rly messed up the tranny, i had to get it fixed cus it was choking frequently= 4-5k. this was after switching over from my stick ek =/. so if i had known better i wouldve solely used the brakes.
PhantomZX
10-01-06 10:35 AM
