IS350 differential fluid change DIY
Old 09-01-14, 07:50 AM
  #91
Ants350
Ants350's Avatar
Originally Posted by Gville350
So today I took the opportunity to finally do the DIY rear carrier gear oil change. Was pretty straight-forward, as I expected. Instead of using a hand pump or some other off-the-shelf item, I went straight-up backyard mechanic and just used gravity and 6ft of clear tubing. Used Lucas full syn 80w-90 gear oil, and the right from the get-go I could tell it is smoother. So for those that don't wanna spend unnecessary funds on a "pump" you'll use once, twice...whatever, spend the $3 on tubing and do this : Used some electrical tape around the end of the hose and wrapped it around the diff to ensure it didn't pop out of the housing during feeding. Definitely worth the 1hr!
So does this go the same for 250 rwd? Ive been debating to this. Also you don't need to take any tires off? When filling it back up it just flowed right in easy?
Old 09-01-14, 09:05 AM
  #92
scott1256c
scott1256c's Avatar
no need to remove tires. you will have to jack the car up a bit to get under there. Make sure to use stands or block the car somehow. I don't know how Gville350 knew when to stop pouring. I used a 1L plastic suction gun to squirt stuff in. That cost me about $8. When I saw a few drips coming out, I sucked back in a bit of fluid and checked and level was good.
Old 09-01-14, 09:11 AM
  #93
4TehNguyen
4TehNguyen's Avatar
you can use a turkey baster too if you dont have a pump
Old 09-01-14, 11:23 AM
  #94
Gville350
Gville350's Avatar
I have an IS350 RWD, so yes...RWD, no matter if 250 or 350.
Like in my pic, obviously I left the wheel on.
Sure did; you just need the help the fluid down by squeezing the bottle.
You remove the fill plug to obviously fill the carrier; once it starts spilling out of that hole, put the plug back in with the new crush washer.
Old 09-01-14, 05:03 PM
  #95
Ants350
Ants350's Avatar
I have an IS350 RWD, so yes...RWD, no matter if 250 or 350. Like in my pic, obviously I left the wheel on. Sure did; you just need the help the fluid down by squeezing the bottle. You remove the fill plug to obviously fill the carrier; once it starts spilling out of that hole, put the plug back in with the new crush washer.
Obviuosly pretty easy I will attempt.
Old 05-15-17, 07:05 AM
  #96
daageep
daageep's Avatar
hey guys, I just replaced my 07 IS350's differential fluid and thought I would post some pictures of the fill/drain bolts as the ones from the front page are down. fyi the fill/drain bolts are on the passenger side.
the following pic is from the rear passenger point of view with the wheel off. the hole in the picture is the fill hole. i do not have a picture of the fill bolt but the bolt has some writing on it, something along the lines of "see owner's manual for oil type", so it should be easy to recognize.
the next picture is also from the passenger side but at a lower angle. the hole at the bottom of the differential is the drain hole.
it was a pain in the butt to remove the bolts. i ended up using a 10mm hex socket and a 3/8 breaker bar (no extensions) on the bolts to remove them. it would help to jack the car up as high up as possible so that the breaker bar clears the floor. I used mobil 1 75/90. good luck.
Old 05-19-17, 08:57 AM
  #97
Leander311
Leander311's Avatar
Has anyone done a UOA on their used diff oil or replaced theirs for any reason other than warm fuzzies?
Lexi ('09 IS350) is over 190k on her original diff oil, and I'm thinking of keeping her another year or three... Thx!
Old 05-19-17, 09:23 AM
  #98
Zmon
Zmon's Avatar
I haven't seen a UOA for the diff fluid yet. Although, at 190k, and if original fluid, it probably should be changed. I'm sure the drain plug has a ton of metal shavings on it.
Last edited by Zmon; 05-20-17 at 09:43 PM. Reason: lol, cleaned. Meant to say changed.
Old 05-19-17, 11:07 AM
  #99
redspencer
OG Member
redspencer's Avatar
Here's one that I did a few months back (I think I might be the only CL IS350 owner with a report). Sample was taken at 81,000 miles after a full fluid flush was performed.
Leander311 (05-19-17)
Old 05-19-17, 12:18 PM
  #100
Gville350
Gville350's Avatar
^Red, was that the report from the trans or the rear diff? Says Aisin A76OE in the title of the report.
Old 05-19-17, 01:17 PM
  #101
redspencer
OG Member
redspencer's Avatar
@ myself for misreading the thread title. My UOA was for the transmission fluid.
I did get the rear differential fluid changed a couple months back but unfortunately I didn't get the used fluid sampled. It's not a bad idea though as it would help me to determine on whether or not I'm changing out the gear oil too frequently (currently changing out fluid every 30k miles).
Old 05-19-17, 05:30 PM
  #102
Zmon
Zmon's Avatar
Lolz, I didn't catch that either when I read your UOA.
I may end up sending mine in for a UOA, changed it about 40k ago, may end up changing it soon.
Old 05-20-17, 10:49 AM
  #103
dorkacho
dorkacho's Avatar
how often is diff fluid supposed to be changed?
Old 05-20-17, 09:23 PM
  #104
andper10
andper10's Avatar
Originally Posted by Zmon
I haven't seen a UOA for the diff fluid yet. Although, at 190k, and if original fluid, it probably should be cleaned. I'm sure the drain plug has a ton of metal shavings on it.
Here is my UOA from a while back. There was no record of a diff fluid change in the car's Lexus service records despite of plenty of other service records.
Attached Thumbnails IS350 differential fluid change DIY-is350-diff-fluid-uoa-2015.jpg
The following 2 users liked this post by andper10:
Leander311 (05-22-17), Zmon (05-20-17)
Old 05-22-17, 07:18 AM
  #105
Leander311
Leander311's Avatar
Wow - Lots of good info here... much appreciated, andper10 and redspencer!! From these two UOA's, I'd be more tempted to replace the tranny fluid than the diff fluid, despite Lexus' claims they are both good for the life of the car... What do they consider said "life" to be? If it's 200k, I'm getting close!
Quick Reply: IS350 differential fluid change DIY
