Installing 19" (235/35/19) AWD and F-Sport Springs. Am I going to rub?
02-10-09, 10:46 AM
Should I expect any rub with this set up? Its AWD so the wheels will be 235/35/19 all the way around, and the F-Sport springs drop about 1 inch.
What should I expect?
02-10-09, 11:01 AM
maybe.
if the rubbing bothers you, just roll the fenders.
02-10-09, 11:11 AM
Quote:
Originally Posted by
chrIS250
maybe.
how would I go about doing that? I read that phrase here a lot but don't know how....
thanks
02-10-09, 11:55 AM
if you take it to a shop and tell them to roll your fenders...they will know exactly what it means.
just do a search.
02-10-09, 12:50 PM
I was going to post up the same question as I'm doing exactly the same thing - 235/35/19 on AWD with F-Sport. Anyone out there with the identical setup willing to share their experience?
02-10-09, 01:19 PM
hell....if 19s rub then might as well go with 20s. thats my philosoFy! i mean, thats the whole reason im stayin away from 20s. if imma get the same result with both then 20s it is
02-10-09, 02:49 PM
i don't think it will rub, doesnt it have to do more with the offset of the wheels if it does rub?
02-10-09, 02:52 PM
those tires and 19" rims are fine. Its the offset you need to worry about. If you are +33 or higher then you are okay and wont need to do anything. If you go more then +33 with the 1" drop then you will need to do some fender mods depending on offset. I was +33 with the same size tire and only had slight rub on the plastic liner going down my driveway with the wheel turned all the way.
02-10-09, 03:35 PM
yeah with offsets beyond +33 you should be fine on that tires..
02-10-09, 04:41 PM
im using 235/35/19 +36 offset with 1.6" drops....it doesn't really rub, but it just rub a little bit when i turn a fast U-turn.
02-10-09, 05:50 PM
My fronts rub on 235's. Dips, bumps, turning... all rubs.
Eibach springs on 19's.
02-10-09, 06:34 PM
offset and wheel width plays....
02-11-09, 12:45 AM
unit74
on AWD? mine doesn't rub this much tho- -"
02-11-09, 08:37 AM
I'm getting wheels w/ a +40 offset, so I should be good, right?
02-11-09, 01:02 PM
unit74
Unit74 - You're running the extra wide rims front and rear, right?
Sybaritic
04-23-17 01:27 PM
thebd
06-16-15 08:54 PM
stlgrym3
11-04-11 09:31 AM
DjVolume
07-20-09 08:36 PM
niteLEX
02-11-09 03:35 PM
