How do you turn off traction control for good!?!?
I have 2008 IS250 Six speed and i like to slide my cars around. Problem is when i turn traction control off it just kicks it right back on when ever the tires start to spin just a little. Ive seen the video for the automatic but the guy says every time you turn your car off the traction control resets it self and turns it back on. I want this **** turned off it really bogs the car down alot?
Thanks
Thanks
Thanks
Thanks
Hold down the TRAC button until both lights come on on the dash. It stays off until you restart the vehicle.
it can not be turned off permanently.
On the 09's when you turn off TRAC control it displays the message TRAC OFF on the display where normally you will have temp, mpg etc. I like to drive with TRAC off sometimes but don't want to see that stupid message all the time. Would rather see the temp. ANyone now of a way to keep track off but get display to stay on Temp???
holding down the button will turn it off until you reach 30mph then it will reactivate itself. by doing the pedal dance it will disable the traction control until you restart the car. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Yes - it stays off until you restart the car.
Javy
Quote:
Originally Posted by suicidesam
sorry for being such a noob, but does the pedal dance permanently disable TRAC + VSC until i restart the car?
-sam
Quote:
Originally Posted by javyLSU
i like knowing that my car will let me get a little out of control if i just do the pedal dance. but if am reading this correctly and i want to loose total control all i have to do is hold down the switch right?
-sam
Holding down the button won't do anything one you reach 30 mph. If you do the pedal dance, you've disabled TRAC + VSC. That's as 'out of control' as you can get. VDIM ABS, Brake Proportioning and Brake Boost, etc... are still enabled, and cannot be turned off.
Javy
Javy
-sam
-sam
Javy
