Swapped my console, steering wheel and door switch lights..
Old 03-12-09, 09:33 AM
  #76
tqlla3k
tqlla3k's Avatar
Originally Posted by chizpxb
Hey guys here is a list of the lights you will need.
console= 1206's(plcc-2's will work as well.)
radio portion= 603's
Steering wheel= plcc-2
door switches= 1206's(once again the plcc-2 will work)
Cool. I am going to give this a shot. Where can I buy the LEDs? Also do they dim with the Dimmer?
What does everyone think about Amber? LOL
Old 03-12-09, 10:26 AM
  #77
2slow
2slow's Avatar
Originally Posted by acefalcon2
i see no DIY but just the end results....anyone has instructions?
I might have a DIY by the end of this month. The LEDs are being sent to me and will arrive the 16th, but i need info on how to remove the steering wheel, start button.
Old 03-12-09, 10:58 AM
  #78
chizpxb
chizpxb's Avatar
On both sides of the steering wheel there is a torx screw( If I remember right I think its a size T15). Loosing both sides and the middle of the steering wheel will come off. Everything stays connected, just flip it on top of the back of the steering wheel. Then where the controls are there is a phillips screw, uncrew it and unplug the wires from the back of the controls, then they are free to mod.(PLCC-2.) Start button just pops out. Use a little force with it..
Old 03-12-09, 11:01 AM
  #79
chizpxb
chizpxb's Avatar
Yes they still dim. Most of my lights I get through oznium.com and the 603's from garage1217.com
Old 03-12-09, 11:53 AM
  #80
2slow
2slow's Avatar
Does start button pop off or does the plastic around it pop off as well? What did you use to pop it off? I tried to force it through the ECT button.
Old 03-12-09, 12:00 PM
  #81
2slow
2slow's Avatar
What does the start button use?
Old 03-12-09, 12:11 PM
  #82
chizpxb
chizpxb's Avatar
Use a little little flathead and pry on the side as u push from the back it. The whole deal will pop out.
Old 03-12-09, 12:13 PM
  #83
chizpxb
chizpxb's Avatar
The start button uses 3mm led.. I unsoldered the led, then solder legs on the plcc-2 led and soldered it on to the board. Pretty simple.
Old 03-12-09, 01:25 PM
  #84
2slow
2slow's Avatar
OK i popped it off. How do i get to the LED? Is it held in by those little clips? I can't seem to find an opening.
Old 03-12-09, 01:43 PM
  #85
chizpxb
chizpxb's Avatar
The top black piece slides off. Then you have to unsolder the 2 legs at the top holding the board in the housing.
Old 03-12-09, 01:54 PM
  #86
sinister2c
sinister2c's Avatar
I saw a DIY on the steering wheel buttons for the Camry on Toyota Nation. Same concept and instructions as an IS.
Old 03-12-09, 09:22 PM
  #87
2slow
2slow's Avatar
hmmm.. slides off which way? I tried everything to get the top off. No luck!
Old 03-12-09, 10:04 PM
  #88
ATX_250
ATX_250's Avatar
Looks awesome......way better!!!
Old 03-12-09, 10:22 PM
  #89
tqlla3k
tqlla3k's Avatar
Originally Posted by 2slow
What happen to the DIY? Everyone is freaking out in your other thread. I mean going crazy!
Start button size? And how did you pop it off? I took the chrom part off, but had trouble with the rest.
I have the start button in my hand as well... how do I take it apart? Darn Clips.
Old 03-12-09, 10:45 PM
  #90
2slow
2slow's Avatar
Yeah i know, i would use more force but i dont want to break it into pieces.
Quick Reply: Swapped my console, steering wheel and door switch lights..
