VSC off switch for 06 IS350.
Old 02-20-09 | 01:53 PM
manchi's Avatar
manchi
Default VSC off switch for 06 IS350.
Hi guys,
We have a friend with a 06 IS350 that does not want to do brake dance everytime the car starts. Has anybody find a way to use toggle switch or retrofit the 07 switch into 06? I searched and saw one person on the myis forum was trying to release a switch kit back in the 06 but I don't see any follow ups. Any help would be appreciated. Thanks in advance.
rammanchi (01-02-24)
Old 02-20-09 | 02:08 PM
suicidesam's Avatar
suicidesam
i still do the pedal dance in my 08
Old 02-20-09 | 03:43 PM
manchi's Avatar
manchi
I have a 07. You don't need to do the pedal dance if you are 07+. Just need to hold the trac button more than 5 sec in Park mode, and when you switch to drive, VSC and trac will be off... But the main problem is that the friend's car is 06, so there has to be a way to do a switch...
Old 02-20-09 | 03:57 PM
javyLSU's Avatar
javyLSU
2IS OG
It's not the switch - it's the VSC ECU that needs to be swapped/retrofitted. Tell your friend to search junkyards for this part. Once he has an 07+ VSC ECU, the pedal dance will become a thing of the past.
Javier
Old 02-23-09 | 10:41 AM
manchi's Avatar
manchi
Cool. Thanks. Is there specific things need to do to retro fitting the VSC ECU?
Old 02-23-09 | 10:45 AM
suicidesam's Avatar
suicidesam
when i do the pedal dance i am able to lay down some rubber but if i take a corner and my rear end tries to break loose why does the car correct itself and not let itself break loose?
Old 02-23-09 | 11:43 AM
javyLSU's Avatar
javyLSU
2IS OG
Remove old, insert new.
Because doing the pedal dance doesn't disable the rest of VDIM - it only disables TRAC/VSC. VDIM is responsible for EBFD (electronic brake force distribution) and BA (brake assist) and these basic ABS and proportioning functions cannot be turned off.
Javier
Old 02-23-09 | 11:59 AM
manchi's Avatar
manchi
Is the VSC computer the same as the ABS(with skip control) computer? Where is the ECU locate at?
Old 02-23-09 | 01:01 PM
manchi's Avatar
manchi
Found it under passenger glove box. Thanks.
albis350
05-18-10 09:51 PM
DaWhole9
02-20-08 07:05 AM
uschardcor
03-02-07 09:13 PM
NovaIS350
08-19-06 10:17 AM
Quick Reply: VSC off switch for 06 IS350.
