**DIY TOM'S/BLITZ THROTTLE CONTROL (56k Warning) **
All this mod does is lie about how far you pushed the gas pedal.
You can get the same result, free, by pushing the gas pedal harder.
It is -nothing- like ECT-Power mode, which changes _transmission_ behavior, not throttle behavior.
Just look at the directions, and see -where- it connects.
It's sitting between your gas pedal and the rest of the drive by wire system.
So all it's doing is changing the "he pushed the pedal 20%" output from the pedal into "He pushed it 50%" to send upstream.
(or 70%, or 90% depending which setting you put it on)
This is what happen when people don't read the thread and start making assumptions.. ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Yeah, it doesn't make your car faster.. but how often do you race? This is for people who drive their car normally and want a quicker throttle response. Btw, PWR mode is on par with the lowest mode on the unit. I will put your imagination on the highest mode..
![Slap](https://www.clublexus.com/forums/images/smilies/slap.gif)
Exactly what I was thinking how this works. It just sits in series with the gas pedal and the throttle. It doesn't connect anywhere else. I guess it would give you a false sense that the car is faster because you are lying to the computer you're pressing the pedal further than you actually are. Each setting you put it at is just increasing the increment it lies to the computer. IE: Lowest Setting: You press the pedal 5%, it feeds 15%, Highest Setting: You press the pedal 5%, it feeds 30%. WOT probably comes sooner than it should and pressing the pedal down further probably doesn't do squat anymore.
Thanks for the writeup though, if you're happy with it, that's all it matters. It just may not be for everybody.
You guys are local.. come by and check it out..
Consider it, I never thought this will make such a huge impact to my car.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
It makes the car feel like you pressed the gas more than you did.
I don't need to drive his car to feel what pressing the gas more feels like, I can do that in my car. Free. By pressing the gas more.
If you're happy with it, great... but if you think it's doing anything other than lying about how far you pressed the gas pedal the only person you're fooling is you.
Received 1,063 Likes
^^ Call it want you want boys.... ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
The fact is that, the Throttle Lag is GONE.....
I was impressed when I test drove the ASPEC TOM's IS350 Marketing car..
... I was even more impressed when I test drove a 2008 LS460 with the same unit installed..
The stock LS460 has major lag compared to a stock IS350.
With the unit installed, there was a HUGE improvement in throttle response, which includes gas pedal "bite" for both cars.
Sort of the reverse psychology from changing out the High Friction Dusty Pads that "bite" as soon as you touch the brake pedal to then installing the low dust, less grabby brake pads..
Again, this is just my un-biased opinion, since I don't own one.
Joe Z
Joe Z
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
