IS 350 Tires
Old 02-28-09, 01:40 PM
nwhuey
nwhuey's Avatar
I have had the tires for about 200 miles or so, tread wear looks even, i'll try to take some pics and post them
Old 02-28-09, 04:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,989 Likes on 2,414 Posts
Originally Posted by mvlbr
Most people go 245/40R18 on the rear.
Why would you put the wrong size tire on the car? OEM is 255/40/18. You said you want your speedo to be correct, well, putting a narrower tire with the same aspect ratio will definitely skew your speedo readings and alter your geometry. Doesn't make any sense at all.
Old 02-28-09, 06:05 PM
Gr8Dane
Gr8Dane's Avatar
Put a 265-35-18 not a 255-35-18, the s-drive doesn't comes in that size. I would find another tire that is the 255-40-18, there are tons to choose from depending on your $.
BTW, the S-drive is an excellent tire, and there is quite a bit of mark up on them, you should be able to talk Dis. Tire down a bit. Check out their wholesale website for prices.
www.discounttiredirect.com
Old 03-01-09, 11:47 AM
mvlbr
mvlbr's Avatar
The S.Drive is not available in a 255/40R18 only 255/35R18 or 245/40R18.
Since 245/40R18 is closer in overall diameter to the 255/40R18 I would suggest that size over the 255/35R18 if he really wants the S.Drive . BTW read all my posts on this thread before criticizing
Old 01-29-10, 06:04 PM
JimIs350
JimIs350's Avatar
The stock tires on my IS 350 are 225/40/18 (front) and 255/40/18 (rear). I am considering the 35 ratio instead of the stock 40 ratio. Other than lowering the car ~0.5" (actually should improve handing), are there other side affects or concerns with the lower tires? Note that the F-Sport lowering springs drop the car an inch.
I am assuming the look of the car will not change much from the side, and hope the tires/wheels will not look too small in the wheel wells.
Old 01-29-10, 06:42 PM
shui3000
shui3000's Avatar
I'm using 255/35/18 on my rears. I'm using kuhmo ecsta asx, and they're awesome.
Old 01-30-10, 02:10 PM
DGZis350
DGZis350's Avatar
HTRZIII are excellent tires. I have had them for about 11 mos now. I have put about 12k on these tires so far. Roid noise is quiet and grip is excellent. Highly recommended for the price also. Great Value.
Ian
Attached Thumbnails IS 350 Tires-brand-new-sumitomo-htr-ziii-tires-008.jpg   IS 350 Tires-brand-new-sumitomo-htr-ziii-tires-004.jpg   IS 350 Tires-brand-new-sumitomo-htr-ziii-tires-024.jpg
Old 01-31-10, 05:49 PM
RickyCRX
RickyCRX's Avatar
Putting a lower profile tire on there will cause your speedometer to read higher than you are actually going and will cause you to rack up mileage quicker than you normally would.
Old 01-31-10, 10:15 PM
Tmirk
Tmirk's Avatar
Sumitomo are awesome! MY experience is less road noise, better wear, good performance, and you can flip them side to side as they are not directional!
Old 02-01-10, 09:41 AM
4TehNguyen
4TehNguyen's Avatar
I have the Sumitomos also, I like them over Bridgestone OEMs
Old 02-01-10, 03:29 PM
gnode
gnode's Avatar
So do 265/35/18s work on stock rear wheels? Would let us squeeze in to these: http://www.tirerack.com/tires/tires....omCompare1=yes
And the 35 on the 265 would be closer in height to the 40 on a 255.
265 x .35 = 92.75
255 x .40 = 102
Only lowers the car 9.25 mm.
Is there a way to reset the speedo to account for a shorter tire?
Old 11-10-11, 09:27 AM
08lexus350
08lexus350's Avatar
can anyone tell me if Bridgestone Blizzak winter tires WS60 245/50R18 on the rear would be okay on stock wheels?? thanks
Old 11-10-11, 09:28 AM
08lexus350
08lexus350's Avatar
i have a 2008 lexus is350,
sade04
01-30-17 06:36 AM
Patrician
01-04-13 11:45 PM
noosense00
04-15-05 03:07 PM
b1gredek
Wheels and Tires Classifieds
02-01-04 10:12 PM
Quick Reply: IS 350 Tires
