IS 350 Tires
I have 30,000 miles on my tires and it's time reload. I'm thinking about getting the Yokohama S.drives. I like the price at discount tire and reviews however they don't have the correct OEM size for the rears. I was thinking about going with this combo.
Fronts = S.drive 225/40r 18
Rears = S.drive 255/35r 18
Has anyone gone this direction? Or any thoughts would be appreciated.
Thanks
Thanks
Here are the overall diameters of the following tires:
255/40R18 = 26.03"
245/40R18 = 25.71"
255/35R18 = 25.02" So basically 1" lower in overall diameter
Just go with the 245/40R18 which is closer in height and probably cheaper.
255/40R18 = 26.03"
245/40R18 = 25.71"
Overall width:
255/35R18 = 10.2"
245/40R18 = 9.9"
Is a 1/3 of an inch even noticeable?
I'd rather be closer in overall diameter than in width so it won't throw off my speedometer too much not to mention you'll be a full inch lower on the rear than stock with that 35 series. That's just my opinion either way ideally would have to be the 255/40R18 but it's up to the op to decide what he wants to do. BTW why don't you just go with Sumitomo HTRZIII from tirerack? They have the fronts(225/40R18) for $111 each and the rear(255/40R18) for $153 each.
255/35R18 = 10.2"
245/40R18 = 9.9"
Overall width:
255/35R18 = 10.2"
245/40R18 = 9.9"
255/35R18 = 10.2"
245/40R18 = 9.9"
Michelin Pilot Sport A/S Plus
Bridgestone Potenza RE050A Pole Position.
Can you mis-match tires. I have fairly new Bridgestone Potenza RE050 on the FRONTS for 18". Do I have to get the same tire for the REAR? Will it mess with the differential?
Not to hijack the thread but how are the Sumitomo HTRZIII? Picking either
Reviews seem for the most part positive on tirerack:
http://www.tirerack.com/survey/Surve...ommentStatus=P
And yes you can mismatch in brands from front to rear just make sure that both rears are matching sizes and you'll be fine.
I have the sumitomos htrzIII on my car in the rears and yokohomas on the front, I don't really notice a difference from having the stock tires, if your really a avid car person and notice tiny things then you might have some problems. But I did not notice anything different, and for the price of them its great to have them.
