HID bi-adaptive
I just got my 09" which comes with HID bi-adaptive. Problem is i don't see it move. It stays still. I read through the manual and i had to turn off some switch to get the HID on but still no difference. Is this normal? My friend's ES you can totally see the lights move once you move the steering wheel.
There is a **** on the left side next to steering wheel where you adjust the tire pressure initialization and speed limiter light, there's an option to turn off/on AFS light. There is no dash indicator on the dash whether it's on or not. Another way to tell is turn on headlight and start engine in your garage, you can see the headlights move up and down once.
but there are no lights or anything on your dash? If I recall its on the far right. I had it flash once on the IS, cant recall why, but it reset when I turned the car off and back on. Go down a really dark street and try to turn it on and off and see what you get if the 09 model allows you to do this.
They move more when you go left then when you go right. Its possible your lights are pointing to high so you dont see them move??
Your right the car needs to be in motion. I didn't get a chance to drive out on the streets to test this yet. Will do that when i get home.
09's definitely have that option.... and you should turn it on not off for it to move.... and it moves depending on the angle of your steering wheel... the more you turn... the more likely you're able to notice it.....
