VSC light Came out!! Help me!!!
Hi~Guys.
I havin a probelm with my VSC light.
Actually, after I changed the high beam bulb, the VSC light came out with
checking engine light.
Is there any method to turn it off?
If I go to dealer, do I have to pay??
Even though I changed bulbs many times with my friends car, it didn't
happened at all.
I hope I would solve with you guys help!!
Thanks guys!![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
happened at all.
Thanks guys!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
It shows here you are from the USA, but dang i'd be surprised if english was not your 2nd language.
You mean your vsc light came ON? or literally it popped out of your dash? You said it came "out" twice (in your subject and in the body) so I am double checking here.
unplug your negative cable on your car for 5 min then plug it back in. You could do a search on here also with VSC+headlight. If you hit that little arm under the car you can cause that, but i doubt you did that.
Hmm, good point.
Actually, the light popped out of the dash like Check VSC.
Could you let me know more specifically?
I live in Dallas TX now kk
I hope we could keep in touch some day.
Thanks~! anyway ^ ^
Thanks~! anyway ^ ^
After Poped out VSC light, I drived about 10 minutes, then it turned off.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Ya, you might be true. When I set it up, I displaced air intaker also.
Now! It solved!
Thanks guys. ^^
