Bigger is better
Old 03-08-09 | 05:45 PM
ankurman20's Avatar
ankurman20
CL Folding 25,000
damn... considering it... how much did it run you total with installation and where did you get it from?
Old 03-08-09 | 05:46 PM
jns350's Avatar
jns350
very nice!!! I didn't realize how much bigger the 350 brakes were compared to the 250..never been curious to know..maybe now I will appreciate my stock brakes more....very nicely done. Do you feel any difference?
Old 03-08-09 | 08:21 PM
blklexo818's Avatar
blklexo818
You guys think the is350 kit will fit an is250's stock rims if it has spacers? Im thinking spacers wont even matter but I just want to make sure
Old 03-08-09 | 08:39 PM
iLexi's Avatar
iLexi
good job. =] how much was it all together for the swap
Old 03-08-09 | 09:14 PM
acefalcon2's Avatar
acefalcon2
doubt you'll need spacers... unless you have the 17" wheels.... if you got the stock 18s... you should be good..
Old 03-08-09 | 09:24 PM
XprincoX's Avatar
XprincoX
I got mine from another CL members so you can't really compare my prices.
For comparison sewell sells the kit for $787: linkie
The IS350 brakes should fit the stock 17's without any problem since orig equip are 17's. 18 or 19 stocks should be fine as well.
https://www.clublexus.com/forums/sus...stock-17s.html
Old 03-09-09 | 09:50 PM
blk250's Avatar
blk250
nice setup...how is ur braking now vs. previously?
Old 03-09-09 | 11:08 PM
SeOuLiS250's Avatar
SeOuLiS250
nice
I can't wait to do mine
Old 03-09-09 | 11:15 PM
XprincoX's Avatar
XprincoX
Your stopping power is slightly improved with the bigger rotors and calipers. The brake sensitivity also doesn't seem as twitchy/grabby as before.
Old 03-10-09 | 01:00 AM
blklexo818's Avatar
blklexo818
are there drilled/slotted rotors for the is350? i'm doing a is350 brake swap, already found the calipers..just need the drilled/slotted rotors -_- i just found the drilled/slotted ones from stoptech in the rears..need em up front
Old 03-10-09 | 01:02 AM
Nigel-JDMParts's Avatar
Nigel-JDMParts
WOT, that's CLOSE!!!!!!!!!
Old 03-10-09 | 01:03 AM
Nigel-JDMParts
hit me up, Rotora have both front and rear I remember.
Old 03-10-09 | 01:05 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
lookin good!
Old 03-10-09 | 01:34 AM
XprincoX's Avatar
XprincoX
yes they do make slot/drilled but alot of people will not recommend it. There was a whole debate of why not to use slot or drilled rotors. Search in the brake forum..
https://www.clublexus.com/forums/sus...rs-help-2.html
that's what i told you! Good thing i got those spacers. Even tommy was shocked how close it was. It's literally bare min clearance without any issues.
Old 03-10-09 | 08:00 AM
Kurtz's Avatar
Kurtz
Not really.
Larger brakes will not stop the car in any shorter distance than the stock ones will.
Brakes don't stop the car, tires do.
Changing brake parts -can- certainly change the "feel" of the system, but it won't make the car stop in any shorter distance.
And yes, drilling is the worst thing you can do to a rotor...nobody who understands brakes really debates that... for a street car a drilled rotor is inferior in every single way to a blank undrilled one. (except arguably that the drilled one "looks" better).
Slotted on the other hand can be useful if you use the car at the track, but otherwise just stick to blank.
