Bigger is better
Bigger is better
Finally got my IS350 bbk installed. So for those of you guys wondering if you can swap IS250 small brakes with a IS350 bbk YES YOU CAN! It's pretty much a direct swap: rotors, calipers, and splash guards.
Special thanks to Tommy @ Musicbox for the install and Nigel for some parts.
Enough talking on the pics:
IS250(296mm) rotor vs IS350 (334mm) rotor:
Fully mounted: (yes i know decal is backwards... i'll fix it when i have time )
The closest clearance ever... 2mm lol
Before:
After much better:
Spotted Tommy's new projector car.
Before:
After much better:
Arent your lexus decals the wrong way round? They look a lot better with the words facing the other way IMO
LOL...I could only get as close as 3mm?? and I had to shave down the front calipers a little bit to fit a 3mm spacer?? There must be something different on the IS250 that allows the smaller spacer. Why not just add the 1 extra mm (3mm spacer) or just go 5mm? There is going to be some flex so you will hit the caliper. I dont thing you will damage the rims but it will chip/nick up those nicely painted calipers.
Looks great Tony
Looks great Tony
i'd stick a bigger spacer on the front wheels to be safe...that gap looks a little too close for comfort.
Or you can use this as an excuse to get new wheels with a more appropriate offset
nice set up bro...my calipers are pretty close to my Varianzas as well. too close for comfort. i wanna buy bigger spacers but like the way the wheels are sitting right now...flushed with the fender. u planning to get bigger spacers? mines are 19X8.5 +35 in the front.
