Location of FR and LR spkr outputs
Edit to Title: "FR and FL" not "FR and LR"
Could anyone confirm which plug(s) on the non-ml amp has the front right and front left woofer speaker outputs?
The colors for the left front woofer is red and white and the right front woofer is brown and pink. Right now I have the signal for the left front woofer tapped on the same plug that shares the woofer outputs which is the second plug back starting from the front the car.
I have the signal for the right front woofer tapped on the plug that is furthest to the rear of the car or the fourth plug from the front.
Is this the correct location for the front left and right speakers?
Thanks in advance.
Thanks in advance.
search is your friend!!!!!consider this a help for a fellow Kamaaina. If I didnt guess wrong from your handle
https://www.clublexus.com/forums/is-...-overview.html
