How Many Gears
Hey Guys, how many gears are there in the Auto Transmission?
I noticed that the car shifts gears some times but the gear number doesnt change, so does that mean there are 'half gears'...I know it sounds stupid, but my curiosity is driving me nuts...lol
It's got 6 speeds. There are no hidden or additional gears.
Overdrive is a term that means any gear less than 1:1, it's not a special mode.
The car has 6 forward gears, all of which should display on the correct screen of the multi-display as the car shifts through them. (which is NOT the same thing as the gear # that shows up in S mode)
Which gears does it lockup in, just 5 and 6?
Tech Info Resource
Depends. If standard lock is working, 5 & 6 only.
If flex lock is working, 3 - 6.
The ECM operates the lock-up timing control in order to improve the fuel consumption performance while in top gear with the shift lever in the S4 or S5 range, and in 5th or 6th gear with the shift lever in the S6 range or D position.
In the low-to-mid-speed range... ...The flex lock-up clutch control operates in the 3rd, 4th, 5th and 6th gears in both D position and S6 range, 3rd, 4th and 5th gears in the S5 range and 3rd and 4th gears in the S4 range.
And now for the dumb question: how does one know which of these locking types is happening?
I don't have any problems with my display or shifting, but was fascinated by the explanation from lobuxracer.
