OEM wheel studs long enough to put on 5mm spacers?
Old 03-10-09, 11:01 AM
mdgrwl
mdgrwl's Avatar
Default OEM wheel studs long enough to put on 5mm spacers?
The the OE studs long enough to put on an H&R 5mm spacer? I believe H&R says that a lungnut needs a full 6 turns in order to be safe. Will OE studs do this with a 5mm spacer on there?
Old 03-10-09, 11:37 AM
nicholasg
nicholasg's Avatar
With the spacers on, how many turns of the lugnuts are you getting?
Old 03-10-09, 11:41 AM
tfz_hebe89
tfz_hebe89's Avatar
Yes, I put 5mm spacer on the rear wheels without changing studs..and I still have enough turns.
Old 03-10-09, 11:50 AM
mdgrwl
mdgrwl's Avatar
I haven't bought em' yet so I didn't try it. Wondering before I buy em if I should schedual an appointment w/ my shop to install the studs.
Old 03-10-09, 01:26 PM
iLexi
iLexi's Avatar
Hey tfz did the wheel spacer make a big difference? Can you tell it looks better?
Old 03-10-09, 02:34 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
I have 5mm spacers on my car front and rear with FSport wheels. No issues.
Old 03-10-09, 02:36 PM
nicholasg
nicholasg's Avatar
Do you rub at all? what size tires? Are you lowered?
Old 03-10-09, 02:41 PM
RTIS250
RTIS250's Avatar
Lowered on eibach pro kit springs. 225/35 and 255/35 tires. Absolutely no rubbing. I can probably even go to 10mm spacers front and rear and not rub.
Old 03-10-09, 02:59 PM
acefalcon2
acefalcon2's Avatar
well you are using F-Sport and my guess is... their offsets are in the 40 range i guess... you could go more towards 12mm rather than 10...
Old 03-10-09, 03:06 PM
wongerZ
wongerZ's Avatar
i was thinking the same thing also...i would try this out to see how many turns i have but i dont have any 5mm spacers lying around...i have a +34 TE37...someone let me know if i can just use the oem studs..thanks!
Old 03-10-09, 03:10 PM
DoHwan
DoHwan's Avatar
H&R 5mm spacers come with longer studs so just install them. all you need is a hammer
Old 03-10-09, 04:09 PM
RTIS250
RTIS250's Avatar
Yes, the FSport wheels are +40. So im running an effective +35 offset right now. Eventually i plan on getting larger spacers, but im happy with what i have for now.
Old 03-10-09, 06:06 PM
tfz_hebe89
tfz_hebe89's Avatar
yes..I test fit the wheels without the spacers and with the spacers I could tell the difference, even if it's only 5mm. I;m running 19x10 in the rear +43 and with the spacers it brings it to +38 = flush enough for me.
4LisaJean
10-03-11 06:53 AM
LilMan23
02-09-11 02:28 PM
designo
09-21-10 05:25 PM
BennyJ
05-03-10 09:56 PM
fr0st
Wheels, Tires & Brakes Forum
04-30-10 08:26 PM
Quick Reply: OEM wheel studs long enough to put on 5mm spacers?
