Horrible camber issues (Pics)
My 2 front tires are wearing horribly on the inside edges. As you can see I'm not even down to the wear bars on the middle and outside of the tire...but that inner edge is just gone. I am lowered on Eibach Pro-kit springs.
Are there any solutions for this? I have never hit a curb or pothole or anything.
Is anyone else running the pro-kit having similar issues?
Have you taken this car to have an alignment/camber/toe adjustment done?
Chances are a simple toe adjustment should take care of this problem considering you lowered your car.
Try that - should be just fine.
Does anyone offer a camber adjustment kit for this car yet? I plan on getting 20's within the next month and I'm trying to run through tires on those. I also plan on getting coils and going even lower (think djkhanvict).
Yea I had JM Lexus align it right after I put the springs on, which was about 8000 miles ago. They thought I had a bent control arm or something until I told them it was lowered.
Springs do settle over time - just a little
Oh it definitely looks lower then when I originally put them on, I was just always told that camber was something that could not be adjusted on this car therefore I was going to have to deal with it.
Those tires look exactly like my old tires did. Went to get an alignment, and my right front toe was -0.28. You need new fronts and an alignment asap.
I'm dropped on F-Sports btw.
