Installed Ichiba V2 Spacers
Old 03-25-09, 10:20 PM
rli2bcz
rli2bcz's Avatar
lookin good man. keep it up!
Old 03-25-09, 11:40 PM
blklexo818
blklexo818's Avatar
u guys think 20mm in the rear would have a chance of rubbing w/ the stock tires/rims? 255s rear 215 front
Old 03-26-09, 12:05 AM
jns350
jns350's Avatar
wheels really pop now...great what just adding spacers can do for wheels!!!!
Old 03-26-09, 12:18 PM
linh811
linh811's Avatar
can you provide contact info where I can order these spacers?
Old 03-27-09, 01:58 PM
SoCal35
SoCal35's Avatar
I purchased mine through a private seller. You can try optionimports.com. I believe that there are vendors in the marketplace section also that sell them.
Old 03-28-09, 01:19 PM
is4fsr
is4fsr's Avatar
Optionimports.com. They price match as well. Called and told them I saw it cheaper at a different site and they price match. They do check the other site though so don't make it up.
Old 03-28-09, 09:13 PM
ohno
ohno's Avatar
Looks really nice..
Old 03-28-09, 11:31 PM
Shoganai
Shoganai's Avatar
i have 10's i just might have to go 15mm after seeing this
Old 03-29-09, 12:25 PM
nicholasg
nicholasg's Avatar
looks good man!
Old 03-29-09, 01:05 PM
Bobby206
Bobby206's Avatar
beautiful! So no rubbing issues thus far?
Old 03-29-09, 01:06 PM
Hayk
Hayk's Avatar
Noob question, can you put spacers on the AWD? I heard something about not being able to use staggered wheels or else it will mess up the differential. Do spacers have anything to do with that, and if I did put them on, would they have to be the same size front to rear?
Old 03-29-09, 03:43 PM
SoCal35
SoCal35's Avatar
The only rubbing issue I do have is when I go over a dip (not the intense kind where you could scrape your front lip) on the freeway or street at a 50+mph speed, I'll slightly- very slightly- rub on my passenger side rear tire. Not bad at all. I think this occurs because I'm only on Eibach springs, which I feel are soft springs. I'm sure if I had coilovers and could adjust the dampening, a stiffer setup would prevent this.
Old 03-29-09, 04:02 PM
SoCal35
SoCal35's Avatar
I believe you can put spacers on AWD. I just did a search and haven't found any negatives about doing so. As far as being same size front and rear, I'm not sure, but I'm going to ASSUME yes, especially if you stick with the stock wheels. I believe stock wheels for AWD are the same width all around- anyone have input?
Old 03-29-09, 04:17 PM
SoCal35
SoCal35's Avatar
Oh yeah one more thing, the wheel setup I have right now isn't gonna be on for much longer. Just purchased a new set and gonna try to install next weekend pending a tire situation.
Hmm... what to do with the Rays G35 wheels...
thespaz18
14
01-12-11 04:57 PM
whazzzzuup
Wheels and Tires Classifieds
06-27-10 10:23 PM
ilmilktea
03-12-09 07:27 PM
RI-Lex
01-12-09 09:54 AM
gassman
04-01-07 02:20 PM
Quick Reply: Installed Ichiba V2 Spacers
